It is currently Wed Jul 16, 2025 3:21 pm
 Post subject: How do these come off??
PostPosted: Wed May 16, 2018 11:09 pm
Hey mini dudes,
I’m stripping the rear subframe and need to get these things off but turning the nut only spins the other end. Is a special tool required?
B
Also, what are these rubber blocks mounted to the subframe for?
Zulu...
1967 mini Cooper S
PostPosted: Wed May 16, 2018 11:22 pm
With the spinning thing... see those two little holes in the face of the other end? They are for a pin spanner, or whatever else you can find that will do the same job. Search for 'pin spanner' on ebay. They are not expensive and are adjustable. Alternatively you can try gripping the outside edge of that round end of it with a pair of stillsons or similar.
The rubber blocks are exhaust mounts.
Don't listen to what I am saying... just understand what I mean.
PostPosted: Thu May 17, 2018 8:19 am
I use an angle grinder key to hold the shafts.
:D
PostPosted: Thu May 17, 2018 9:24 am
:D
Me too. I have a large adjustable one for my 9inch grinder. If that doesn't work then I use the grinder!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
