It is currently Tue Jul 15, 2025 5:20 pm
 Post subject: 1970 mini
PostPosted: Sun May 13, 2018 10:58 pm
Can anyone give me the exact position of the horn please .Distance of the 2 holes from the corner of the guard . I have no holes in the front panel in the horn area. Thanks Allen mm distance prob 1/4 holes ,or a measurement from the centre of the bonnet catch
 Post subject: Re: 1970 mini
PostPosted: Sun May 13, 2018 11:09 pm
Were these photos of no assistance or are you going to attach yours to the inner guard?ImageImage
PostPosted: Mon May 14, 2018 7:48 am
What was wrong with your last thread about the horn location?? Plenty of photos and measurements.
viewtopic.php?f=2&t=97154
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Mon May 14, 2018 8:48 pm
TY for the pics looks like the first hole for the horn is 107mm from guard is that correct ? also does the horn bracket fit on the top of the front panel ? TY Allen Seems like there are a lot of holes in this panel so I welded them up I only want the holes that I can use. The new panel fits well just the problem with holes and brackets. Heritage panel could be made anywhere I think I might start fixing these panels and selling them the bonnet lock area takes a bit of time to do.
PostPosted: Mon May 14, 2018 8:54 pm
cgo wrote:
Measurements are 107 (to bonnet grommet hole centre), 152 (to 1st horn bracket hole centre) and 183 (to 2nd horn bracket hole centre) in mm, from edge of RH guard.
Hope this helps.
The bracket sits on top like this.
PostPosted: Mon May 14, 2018 10:36 pm
TY All I will install the horn tomorrow
Allen
