p7676 wrote:
TY for the pics looks like the first hole for the horn is 107mm from guard is that correct ? also does the horn bracket fit on the top of the front panel ? TY Allen Seems like there are a lot of holes in this panel so I welded them up I only want the holes that I can use. The new panel fits well just the problem with holes and brackets. Heritage panel could be made anywhere I think I might start fixing these panels and selling them the bonnet lock area takes a bit of time to do.
cgo wrote:
Measurements are 107 (to bonnet grommet hole centre), 152 (to 1st horn bracket hole centre) and 183 (to 2nd horn bracket hole centre) in mm, from edge of RH guard.
Hope this helps.
The bracket sits on top like this.
