It is currently Tue Jul 15, 2025 11:13 pm
 Post subject: SU Needle
PostPosted: Sun May 13, 2018 10:25 pm
Hello Everyone
Could someone please tell me what the standard needle was for a standard 1098 cc .
At the moment it has a #5 and seems to be a bit rich .
Thanks,
11/1973 (Clubman look alike)
 Post subject: Re: SU Neddle
PostPosted: Sun May 13, 2018 11:01 pm
mmiller6512 wrote:
Hello Everyone
Thanks,
AN needle, Red spring, HS2 carby
PostPosted: Mon May 14, 2018 4:57 pm
Sorry forgot to mention its a HS4 .
PostPosted: Mon May 14, 2018 5:05 pm
I don't think the HS4 was standard on 1098 engines here?
The chart here has the CZ listed for fixed needle and ABJ for bias (spring) needle
https://www.7ent.com/pages/articles-tec ... eedle.html
 Post subject: Re: SU Needle
PostPosted: Mon May 14, 2018 5:31 pm
Yep HS2 was standard.
There are lots of previous questions about this. Just do a search for HS4 needle or the like. search.php?keywords=hs4+needle&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
PostPosted: Mon May 14, 2018 5:57 pm
I found a CP4 works well in an hs4 with sports filter. On a 1098.
PostPosted: Tue May 15, 2018 3:15 pm
Thanks everyone
I have ordered a cp4 and a cz . Ive no idea how it got a hs4 fixed needle #5 in it .
PostPosted: Tue May 15, 2018 3:28 pm
A #5 looks like a plausible option as well
PostPosted: Tue May 15, 2018 7:09 pm
5 needle was used on MG & GT 1965-66 in twin HS4s. Maybe that's where the carb came from?
My little book says that 1098cc minis using HS4 single carb as standard (as in auto minis) for '65-'66-'67-'68-'71 all used DL needles as Std.
If Dr Kev says CP4 works then that's a good guide. CP4 and DL are leaner than #5.
PostPosted: Tue May 15, 2018 9:50 pm
Note I said with sports filter. Ramflo.
CP4 may be a little rich with a stock filter.
