It is currently Tue Jul 15, 2025 2:33 am
 Post subject: 1970 mini C.S
PostPosted: Thu Apr 26, 2018 8:50 pm
Question, Is it worth spending money to fit electronic ignition, if it is what is the best type and where can I buy it?
P7676 TY
 Post subject: Re: 1970 mini C.S
PostPosted: Thu Apr 26, 2018 9:08 pm
Unless your showing the car as period correct then go for a new electronic dissy. They are only $125. Convertible Mini on here sells them.
Here is the 23D4 he sells on Ebay and you can get a top entry cap so you can keep your leads. https://www.ebay.com.au/itm/MORRIS-MINI ... SwQm9ZxXZd
43D4 would be the other non vacuum type to replace the 29D that is NLA.
The advance curve and total advance is better on the new dissys compared to the originals.
