https://ausmini.com/forums/
Mk 1 number plate lights
https://ausmini.com/forums/viewtopic.php?f=2&t=97109
Author:  deluxe67 [ Thu Apr 19, 2018 6:52 pm ]
Post subject:  Mk 1 number plate lights
I'm only getting 10.5 Volts. Is that normal? Seems like a big voltage drop? Ironic it's so close physically to the battery but I guess so far away via the fuse box...
Author:  AEG163job [ Thu Apr 19, 2018 10:00 pm ]
Post subject:  Re: Mk 1 number plate lights
Poor earth connection or resistance somewhere in the live feed. Take a reading at the bullet connectors in the boot for starters.
Author:  drmini in aust [ Fri Apr 20, 2018 5:30 am ]
If you don't have a headlamp relay the current draw through the switch can pull the voltage down on all the lights. Worth adding one... ;)
Author:  deluxe67 [ Fri Apr 20, 2018 12:19 pm ]
Sorted. Getting 12.5V now. Issue was the bullet connector in the boot.....
