It is currently Tue Jul 15, 2025 6:03 am
 Post subject: Mk 1 number plate lights
PostPosted: Thu Apr 19, 2018 6:52 pm
I'm only getting 10.5 Volts. Is that normal? Seems like a big voltage drop? Ironic it's so close physically to the battery but I guess so far away via the fuse box...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Thu Apr 19, 2018 10:00 pm
Poor earth connection or resistance somewhere in the live feed. Take a reading at the bullet connectors in the boot for starters.
PostPosted: Fri Apr 20, 2018 5:30 am
If you don't have a headlamp relay the current draw through the switch can pull the voltage down on all the lights. Worth adding one... ;)
PostPosted: Fri Apr 20, 2018 12:19 pm
Sorted. Getting 12.5V now. Issue was the bullet connector in the boot.....
67 Deluxe
Dry suspension
