Delete Please https://ausmini.com/forums/viewtopic.php?f=2&t=97107 |
Author: | gtogreen1969 [ Wed Apr 18, 2018 1:57 pm ] |
Post subject: | Re: Ram Stack Installation |
You could just drill out the threaded holes in the ram stacks and then use the standard bolts. |
Author: | drmini in aust [ Wed Apr 18, 2018 2:18 pm ] |
Drill the carby holes then. Some SUs are drilled not threaded. Or, machine the outside of the capscrews down so they clear the trumpets. |
Author: | Scoop [ Wed Apr 18, 2018 5:44 pm ] |
gtogreen1969 wrote: You could just drill out the threaded holes in the ram stacks and then use the standard bolts. I would do that. Maybe use cap screws if bolt heads to big but should be ok. |
Author: | Besser [ Thu Apr 19, 2018 9:09 am ] |
Options: Fit studs to the carb and run the nut on or the reverse stud to ram etc Drill them out and side slot so you can insert the fastner in the carb almost the full way then apply trumpet with lugs offset then rotate into position and snug up the fastener Contact supplier and have them solve it at their cost under Australian Consumer Law Glue and tiewire ![]() fit them as dual exhaust tips and smile! |
Author: | 1071 S [ Thu Apr 19, 2018 3:20 pm ] |
Drill out the stacks..you can't bolt two threaded sections together... If the standard allen bolts don't clear you can get dome or button headed allen bolts that will fit. Cheers, Ian |
