https://ausmini.com/forums/
Installing dual circuit brakes in a roundie
https://ausmini.com/forums/viewtopic.php?f=2&t=97090
Author:  jprior2912 [ Thu Apr 12, 2018 2:48 pm ]
Post subject:  Installing dual circuit brakes in a roundie
Hi all,
So when I spoke to engineer, he stated I needed to install dual circuit brakes in the car for it to be signed off with the supercharger.
I can only find a leyland mini dual circuit master cylinder, I was wondering if anyone knew if this fitted a roundnose or not, or what's the best way to go about doing this install?
James
Author:  simon k [ Thu Apr 12, 2018 6:49 pm ]
Post subject:  Re: Installing dual circuit brakes in a roundie
it should all fit fine...
Author:  drmini in aust [ Thu Apr 12, 2018 8:12 pm ]
Your brake servo will only do the front circuit. But that's OK as Mini rear brakes do SFA under heavy braking.
Author:  wild_willy [ Fri Apr 13, 2018 9:36 am ]
As fitted to my J car. Worked well easy fit.
