It is currently Tue Jul 15, 2025 8:11 am
PostPosted: Thu Apr 12, 2018 2:48 pm
Hi all,
So when I spoke to engineer, he stated I needed to install dual circuit brakes in the car for it to be signed off with the supercharger.
I can only find a leyland mini dual circuit master cylinder, I was wondering if anyone knew if this fitted a roundnose or not, or what's the best way to go about doing this install?
James
PostPosted: Thu Apr 12, 2018 6:49 pm
it should all fit fine...
PostPosted: Thu Apr 12, 2018 8:12 pm
Your brake servo will only do the front circuit. But that's OK as Mini rear brakes do SFA under heavy braking.
PostPosted: Fri Apr 13, 2018 9:36 am
As fitted to my J car. Worked well easy fit.
