It is currently Tue Jul 15, 2025 4:17 am
PostPosted: Mon Apr 09, 2018 10:04 pm
As the post says I need to borrow some early hydro lines off someone in Sydney so I can use as a template. I realised all the bits I have with cut off or broken sections won’t do.
Pm or txt 0418 263 295
Thanks
Matt
67 Deluxe under going full resto
PostPosted: Tue Apr 10, 2018 9:08 am
Are you going to make new lines ? They are difficult to make I made new lines last year .If I ever had to make them again I would make each line in 2 parts then join them with a flair joint and blue tip silver solder ,Which is the silver solder used in refrigeration,
Allen
PostPosted: Tue Apr 10, 2018 9:52 am
Yep getting perterk to make them
PostPosted: Tue Apr 10, 2018 12:26 pm
Have sent you a PM
1974 Leyland Clubman
Lots of good machines
Of all the things I have lost, I miss my mind the most.
PostPosted: Wed Apr 11, 2018 3:36 pm
Hi Matt,
I've got a set, they have already been modified with flared fittings for quick disconnect. (not for sale)
PM if interested.
Rgds Mozzie
1970 Mk2
1968 Mk1 project
PostPosted: Wed Apr 11, 2018 3:39 pm
I'm sure they would prefer to be known as Pirtek.
PostPosted: Wed Apr 11, 2018 8:29 pm
Pirtek is correct they will cost $$$ to make If you buy a small tube bender you can make them yourself .Takes a bit of time my hydro lines fit better than the original especially where they meet the ends of the floor .The Bundy tube is readily available from a brake supplier. Anyone know how much Pirtek charge ?
PostPosted: Wed Apr 11, 2018 9:36 pm
What is the specification and/or part number for the bundy tube?
PostPosted: Thu Apr 12, 2018 7:47 am
Found a set and will be made at Pirtek Campbeltown as per John Schmidt’s advice.
PostPosted: Thu Apr 12, 2018 9:42 am
what is the cost ? other members would like to know ??????????
P7676
PostPosted: Thu Apr 12, 2018 11:43 am
P7676 - I know of people who have been looking for this material but have only found brittle version that can't be bent easily. What is yours called and where did you get it?
PostPosted: Thu Apr 12, 2018 4:12 pm
I bought the 3/8 bundy tube from First Choice Automotive Parts, Part number T348 cost me $8.00 per m. They have 3 locations Cardiff NSW 49542744.You cut it to the size you need it comes in a large roll,allow an extra 60mm for double flares,4 double flares cost me $10.00 and any extra length can be taken up under the rear of the car. I bought a tube bender for $37.00 which does 3 different size tubes. The secret in bending is to buy an extra metre of tube then using this scrap tube you can calculate where to start the bends, The radius is the same on the old hydro lines .The tube is malleable like brake lines and if you bend the tube too far jut pull it back using your hands. You also need to keep checking the hydro line on the car .I used to screw the front of the line into the connection then check that allows you to twist the line if necessary. You develop a skill for bending them I found them hard to bend with a beer in one hand .Hot Rodders use this tube all the time. Hopes this helps you will need good skills to bend the lines as I said my lines fit better than the original ones. I am ex Experimental from BMC P7676 I did not want to install my old contaminated lines on the C.S NO leaks pumped up great.
