1970 mini lucas windscreen wiper motor https://ausmini.com/forums/viewtopic.php?f=2&t=97073 |
Author: | p7676 [ Sat Apr 07, 2018 12:35 pm ] |
Post subject: | 1970 mini lucas windscreen wiper motor |
Hello All, Has anyone changed the switch plate on the assembly looks like you cant even take the brushes out. I want to change the switch plate because 2 of the copper prongs have nearly worn away 1 is ok .Looks like you have to cut and join the wires.Would a small amount of solder on the ends be ok? Not sure how long the solder would last as it may wear quickly. P7676 |
Author: | Ian_B [ Sat Apr 07, 2018 2:19 pm ] |
Post subject: | Re: 1970 mini lucas windscreen wiper motor |
Hi Allen We deal with lead free solder at work now .We hate it as it has higher melting point Doesnt flow as well and I assume harder .We have a roll of it and hate the stuff. |
Author: | deluxe67 [ Sat Apr 07, 2018 3:50 pm ] |
Where are you? I think I have a couple around. Your are talking about the brass ring plate that fits to the nylon gear wheel? |
Author: | winabbey [ Sat Apr 07, 2018 6:13 pm ] |
Are you talking about the brass fingers? A replacement part is available from various Mini suppliers. https://minikingdomonline.com.au/produc ... er-motors/ |
