It is currently Thu Jul 17, 2025 5:05 pm
PostPosted: Mon Mar 12, 2018 3:52 pm
Afternoon all,
After some time fixing an extremely odd clutch issue in the wife's 1602, it's time to get back onto the mini. Hay isn't far away :|
Now, question with the wiring.
-Battery positive supply is easy enough and is in situ.
-Upper (large) spade terminal (help!?)
-Lower (small) spade terminal will be the switched trigger for the starter itself?
I'll also have to supply the charge feed from the alternator - I assume it would be easiest and best to go to the battery positive cable?
PostPosted: Mon Mar 12, 2018 7:09 pm
you're right with small one and alt wire. Mine has nothing on big terminal.
PostPosted: Tue Apr 10, 2018 12:39 pm
Well, quick update for anyone with one of these starters - upper large spade terminal is the starter trigger... Which is a pain to find out, once you've cut/terminated/shrink wrapped and zip-tied all your wiring into place :(
PostPosted: Tue Apr 10, 2018 1:13 pm
My 2 cents worth. The large terminal is the starter trigger like was said previously. The smaller spade is not used on a Mini. It is a resistor bypass feed which becomes live with 12Volts + when cranking. These solenoids fit many other applications besides Mini .
"Let us remove your "SHORTS"
PostPosted: Tue Apr 10, 2018 6:16 pm
the resistor bypass is used with some Minis over here. 998ccm Austin-Rover ones from 1984 to 91
Rover 214 atm ....
Users browsing this forum: Bing [Bot] and 89 guests
