Window washers https://ausmini.com/forums/viewtopic.php?f=2&t=97052 |
Author: | belldane [ Sun Apr 01, 2018 5:02 pm ] |
Post subject: | Window washers |
This is my second attempt to post my question. No idea what happened to the first one! A rat has decided to chew through the window washer lines. I have fixed the passenger side but need to get the little pisser on the other side out. I have managed to loosen it but will not come out. Any help please? |
Author: | winabbey [ Sun Apr 01, 2018 5:19 pm ] |
Post subject: | Re: Window washers |
What exactly are you trying to do? Detach the plastic tube from the washer jet (a hair drier to soften the tube helps) or remove the jet from the scuttle? |
Author: | belldane [ Sun Apr 01, 2018 5:38 pm ] |
Trying to remove the washer jet as I need to replace the chewed up hose very close to the jet. Thanks |
Author: | winabbey [ Sun Apr 01, 2018 9:23 pm ] |
If it's one of the black plastic jets the shank is threaded with a nut to hold it in place. Is that how yours is? |
Author: | belldane [ Sun Apr 01, 2018 11:35 pm ] |
Nope. Mine is chromed metal. The good stuff they made 48 years ago, |
Author: | belldane [ Mon Apr 02, 2018 4:21 pm ] |
Problem solved. There was a nut to undo. Thanks for your help. |
