16 blade metal fan, which way https://ausmini.com/forums/viewtopic.php?f=2&t=97048 |
Author: | Phil 850 [ Fri Mar 30, 2018 8:37 pm ] |
Post subject: | 16 blade metal fan, which way |
As above, should the reinforcements face the radiator or the engine ? |
Author: | gtogreen1969 [ Fri Mar 30, 2018 9:33 pm ] |
Post subject: | Re: 16 blade metal fan, which way |
Attachment: Fan blade direction Steel mini .jpg
Author: | cooperess [ Sat Mar 31, 2018 11:29 am ] |
Does the steel fan give better cooling than the plastic fan. |
Author: | drmini in aust [ Sat Mar 31, 2018 4:41 pm ] |
I believe so. They don't toss blades off either. ![]() And if they get bent, can be straightened. |
Author: | minimans [ Sun Apr 01, 2018 10:44 am ] |
Yes they do, but they are the noisiest fan available....... |
Author: | drmini in aust [ Sun Apr 01, 2018 12:17 pm ] |
I tried both it and the yellow plastic one. The plastic was way noisier. So I went back to the mk1 16 blade metal one. Isn't the tropical 4 or 6 blade supposed to be the noisy one? |
Author: | minimans [ Sun Apr 01, 2018 1:20 pm ] |
drmini in aust wrote: I tried both it and the yellow plastic one. The plastic was way noisier. So I went back to the mk1 16 blade metal one. Isn't the tropical 4 or 6 blade supposed to be the noisy one? Yes the four blade is very noisy as well! but the 16 blade makes a whiny noise that just grates on me.......... |
