What is the standard height of a mini block 1275 https://ausmini.com/forums/viewtopic.php?f=2&t=97010 |
Author: | kiwiinwgtn [ Thu Mar 22, 2018 6:05 pm ] |
Post subject: | What is the standard height of a mini block 1275 |
As per title would have a the standard height of a cylinder block. I have one in good condition but it looks to have had a couple of mill shaved off the top. Looking to hopefully use it to build a stroker engine. May need to get the piston dish machined to reduce the compression ratio so I can use it. Ta Kiwiinwgtn |
Author: | drmini in aust [ Thu Mar 22, 2018 7:53 pm ] |
Post subject: | Re: What is the standard height of a mini block 1275 |
I will measure one in the morning. Re the pistons, hypatecs are good for strokers as the rings are lower than most others, allowing more to be machined off the top. I reshaped the dish similar to GR's ones. |
Author: | drmini in aust [ Fri Mar 23, 2018 4:52 pm ] |
227mm measured with a new Stanley tape. Standard block still has bore size stampings on. |
Author: | Ian_B [ Sat Mar 24, 2018 5:10 pm ] |
My stroker has hypatecs done by GR There is 10cc in each piston dish |
Author: | kiwiinwgtn [ Fri May 04, 2018 6:19 pm ] |
thanks for the replys Sent from my SM-J530Y using Tapatalk |
