Drum brake minimum thickness https://ausmini.com/forums/viewtopic.php?f=2&t=97008 |
Author: | 70K1100 [ Thu Mar 22, 2018 6:01 pm ] |
Post subject: | Drum brake minimum thickness |
I can't find my workshop manual. Can anyone tell me what the minimum thickness is for a brake drum for the rear of the mini? |
Author: | Matt I [ Thu Mar 22, 2018 6:06 pm ] |
Post subject: | Re: Drum brake minimum thickness |
The new pair I picked up yesterday have 'MAX DIA 179.3MM' cast in to them, which is 7.060", or 60 thou over standard. |
Author: | 70K1100 [ Thu Mar 22, 2018 9:51 pm ] |
Thanks. I'll measure some that I have at home before getting new ones. |
Author: | drjbeam [ Mon Mar 26, 2018 1:58 pm ] |
I wouldn't bother ****ing around with measuring brakes shoes id just go new all the time no question asked Messing around with old brakes parts is like playing Russian roulette i wouldn't do it for around $25 or so a set new |
Author: | DavidE [ Mon Mar 26, 2018 3:46 pm ] |
drjbeam wrote: I wouldn't bother ****ing around with measuring brakes shoes id just go new all the time no question asked Messing around with old brakes parts is like playing Russian roulette i wouldn't do it for around $25 or so a set new Plus 1. |
Author: | greyghost [ Mon Mar 26, 2018 5:01 pm ] |
guys I think you are misunderstanding what is being asked here, they are discussing the "service limit" on the drums themselves, not the shoes seems a bit arbitrarily to throw out the drums each time you change shoes, doesn't it? I have a car here I just removed the drums and binned them and they were over 50 years old, according to the dates on them. |
Author: | gtogreen1969 [ Mon Mar 26, 2018 5:37 pm ] |
greyghost wrote: guys I think you are misunderstanding what is being asked here, they are discussing the "service limit" on the drums themselves, not the shoes seems a bit arbitrarily to throw out the drums each time you change shoes, doesn't it? I have a car here I just removed the drums and binned them and they were over 50 years old, according to the dates on them. I thought the question was answered by Matt I on the very first reply. |
Author: | Goldbrocade_62 [ Mon Mar 26, 2018 6:06 pm ] |
I understand standard what the question is about but bare in mind when skimmed you should you over size brake shoes to compensate for drum machining |
Author: | Matt I [ Mon Mar 26, 2018 6:17 pm ] |
I replaced mine as all the spacer drums I had were either machined oversize or warped, and oversize linings to match the drums were twice the price of new standard ones... I agree that replacing everything generally makes more sense now based on the cost compared with machining and linings to suit. |
