Power options https://ausmini.com/forums/viewtopic.php?f=2&t=96986 |
Author: | zulu_warrior1976 [ Sat Mar 17, 2018 10:25 pm ] |
Post subject: | Power options |
Ok dudes and dudettes, I have a complete 1275 that I want to make mental and put in a mini k. I’m thinking turbo or supercharger. So, NA? Turbo? Or supercharged? Bman |
Author: | ausdino [ Sat Mar 17, 2018 11:59 pm ] |
Post subject: | Re: Power options |
Supercharge with the 40 or 45 dcoe vmacscart kit. Keen to see how they go |
Author: | peterb [ Sun Mar 18, 2018 6:40 am ] |
Why choose? Put both on . ![]() |
Author: | Scoop [ Sun Mar 18, 2018 7:02 am ] |
A sc kit would be reasonably easy to do and would go quite well but I would go turbo. Would be a sqeeze, may need to mod the bulk head though. |
Author: | drmini in aust [ Sun Mar 18, 2018 7:29 am ] |
I hear SC12 parts are getting scarce. Re a turbo, you can get kits now that fit it above the firewall, no cutting needed. Contact 'benjamin' on here. |
Author: | simon k [ Sun Mar 18, 2018 8:30 am ] |
7 port or BMW bike head with a turbo ausdino wrote: Supercharge with the 40 or 45 dcoe vmacscart kit. Keen to see how they go still too many compromises - fueling before the blower that is too small and no charge cooling - can never make any real power |
Author: | timmy201 [ Sun Mar 18, 2018 8:39 am ] |
I think the best bang for your buck will be a turbo if you can do the work yourself. The supercharger kits are an easy option as you can buy the kits with most of the hard work done already. Do you have a current power goal in mind and what kind of spec is the 1275 engine now? |
Author: | Kennomini [ Sun Mar 18, 2018 9:08 pm ] |
Really the sky is the limit when it comes to mods but these days it's all about turbos. A well suited snail for your custom built engine will be better than a sc of the same built style. Also pump E85 is getting more common which means higher comp ratios = MAX POWER ![]() |
