It is currently Tue Jul 15, 2025 7:09 pm
 Post subject: Front Panel
PostPosted: Sun Mar 04, 2018 9:20 pm
Has anyone experienced using this front panel?
Are they available locally and if so where?
https://www.minisport.com/mcr52-18-01-0 ... escription
 Post subject: Re: Front Panel
PostPosted: Mon Mar 05, 2018 10:36 am
The front panels available need modifications. They have extra holes at the top and where the bonnet lock is positioned ,they are different. Also wider area where park light fits and air vent hole rh side ask the supplier they should know this. I have fitted these front panels and I cut the bonnet lock area out of the old panel and weld it to the new panel .I do this work in about 4hrs no body filler required and to remove and fit the new panel takes about a day. You will need a MIG welder. I can get them to fit perfect no body filler required .Not an easy job to do unless you know what you are doing. I used to build protype cars etc.
Allen
Users browsing this forum: Bing [Bot] and 79 guests
