It is currently Wed Jul 16, 2025 12:55 am
 Post subject: Quafe diff
PostPosted: Tue Feb 27, 2018 7:20 am
Can anyone tell me where clearance issues can happen.I notice that when I rotate the pot joints it tightens a bit at a certain point.
Gearbox is an A plus.Thanks in advance
 Post subject: Re: Quafe diff
PostPosted: Tue Feb 27, 2018 7:45 am
Clearance problem I found was the crown wheel bolt heads fouling inside the diff cover. I faced the bolt heads thinner.
PostPosted: Tue Feb 27, 2018 7:54 am
Thanks Kev glad ive picked up on it now rather than later .I dont do gearboxes.Will get my mate onto it
PostPosted: Sat Mar 03, 2018 1:58 pm
Mine was fouling at the widest radius of the diff body and I had to remove a little metal from the g/box case. Can also depend on how you space the diff with the shims.
Users browsing this forum: Bing [Bot] and 87 guests
