Quafe diff https://ausmini.com/forums/viewtopic.php?f=2&t=96898 |
Author: | Ian_B [ Tue Feb 27, 2018 7:20 am ] |
Post subject: | Quafe diff |
Can anyone tell me where clearance issues can happen.I notice that when I rotate the pot joints it tightens a bit at a certain point. Gearbox is an A plus.Thanks in advance |
Author: | drmini in aust [ Tue Feb 27, 2018 7:45 am ] |
Post subject: | Re: Quafe diff |
Clearance problem I found was the crown wheel bolt heads fouling inside the diff cover. I faced the bolt heads thinner. |
Author: | Ian_B [ Tue Feb 27, 2018 7:54 am ] |
Thanks Kev glad ive picked up on it now rather than later .I dont do gearboxes.Will get my mate onto it |
Author: | MiniBob [ Sat Mar 03, 2018 1:58 pm ] |
Mine was fouling at the widest radius of the diff body and I had to remove a little metal from the g/box case. Can also depend on how you space the diff with the shims. |
