Morris Cooper oil pressure guage pipe for sale on e bay. https://ausmini.com/forums/viewtopic.php?f=2&t=96855 |
Author: | ianscampbell [ Tue Feb 20, 2018 7:20 pm ] |
Post subject: | Morris Cooper oil pressure guage pipe for sale on e bay. |
Hi everyone, Can any body remember who was selling the complete preformed oil pressure guage pipe, reinforced rubber hose & clamps on e bay recently? - I was watching the item for months when I didn't need it, but now that I do, I can't find it any more. I reckon it was "minimakeovers" or some one like that. Thanks in advance, Ian. |
Author: | cooperess [ Tue Feb 20, 2018 8:46 pm ] |
Post subject: | Re: Morris Cooper oil pressure guage pipe for sale on e bay. |
Pretty sure I've got one somewhere. |
Author: | wild_willy [ Wed Feb 21, 2018 8:36 pm ] |
Here https://www.ebay.co.uk/itm/Mini-Oil-Pre ... SwVL1WDj~1 |
Author: | goodie [ Fri Feb 23, 2018 6:01 am ] |
How come you need one Ian , is it because yours is damaged or broken ? Reason i ask is i snapped the pipe at the "P"clamp on the side of the block once and repaired it by cutting a piece of brake pipe and sleeving it over the pipe and soldering it ![]() You don't see them popping up for sale too often . |
Author: | drmini in aust [ Fri Feb 23, 2018 6:33 am ] |
You can still buy them new. Not cheap and the hose is cheapo compared to the original. Its only 7mm and the $10 ea clamps hardly hold it. I bought a hose and clamps recently. The original hose was similar to a Mini hydraulic brake hose. Much thicker. |
Author: | gtogreen1969 [ Fri Feb 23, 2018 2:11 pm ] |
I remember seeing it for over 12 months on ebay. Now you need it the listing is gone. Good luck with the search. I will keep an eye out. |
Author: | drmini in aust [ Wed Mar 07, 2018 8:50 am ] |
I bought some 1/8" USA made fuel vent hose today, it is much thicker and reinforced. At $5 a metre it's heaps cheaper too. And over 8mm thick so will clamp better. ![]() Can't use brake hose, its allergic to motor oil the brake shop says. |
Author: | Bill B [ Thu Mar 08, 2018 10:47 am ] |
For the metal pipe, I remade one with the old ends soldered on, but using copper tubing, which is fairly soft and easily damaged. I think the original was made from steel tubing, but it I couldn't find any in that diameter. |
Author: | cooperess [ Thu Mar 08, 2018 2:52 pm ] |
Pretty sure they are copper |
Author: | AEG163job [ Thu Mar 08, 2018 9:34 pm ] |
Actually, I believe it was copper plated steel tubing. |
Author: | cooperess [ Thu Mar 08, 2018 10:16 pm ] |
I'll try rubbing the spare I have with emery paper just to see. |
Author: | cgo [ Fri Mar 09, 2018 5:42 am ] |
This one looks like steel to me. |
Author: | kiwiinwgtn [ Thu Mar 22, 2018 5:39 pm ] |
You could always try a magnet. To be 100% sure. |
Author: | michaelb [ Fri Mar 23, 2018 6:59 pm ] |
The pipe is originally steel |
Author: | zep [ Mon Mar 26, 2018 1:51 pm ] |
https://www.minispares.com/product/classic/CAM4202.aspx I bought this one as well as the hose, clamps and pipe to gauge |
