How to Remove this Bearing? https://ausmini.com/forums/viewtopic.php?f=2&t=96834 |
Author: | cooperess [ Sat Feb 17, 2018 1:08 pm ] |
Post subject: | How to Remove this Bearing? |
Attachment: Mini Gear Box Nut Removal 001.jpg How does one remove this bearing without wrecking it like I have.
Author: | hpal [ Sat Feb 17, 2018 1:37 pm ] |
Post subject: | Re: How to Remove this Bearing? |
I would assume use a suitable puller, its a need roller yes? |
Author: | simon k [ Sat Feb 17, 2018 2:17 pm ] |
I have a little 3 leg puller I use - I think I had to grind the feet a little thinner to get between the ring and the nut, but that's the way I do it... |
Author: | cooperess [ Sat Feb 17, 2018 2:18 pm ] |
hpal wrote: I would assume use a suitable puller, its a need roller yes? It was until I broke the cage and the needles dropped out.
Author: | Phil 850 [ Sat Feb 17, 2018 2:22 pm ] |
Attachment: IMG_3830.JPG I made one of these from a piece of 50mm square tube. |
Author: | cgo [ Sat Feb 17, 2018 2:23 pm ] |
Have used a small 2 jaw puller. Or read this; http://www.ausmini.com/forums/viewtopic.php?f=25&t=66729 Attachment: puller.JPG Sorry, too late. |
Author: | AEG163job [ Sat Feb 17, 2018 8:27 pm ] |
Removing the bearing from the shaft is easy. Removing the outer shell from the transmission casing is much more fun (which you will now need to do since you've totalled the inner part! ![]() |
Author: | cooperess [ Sat Feb 17, 2018 8:41 pm ] |
Thanks for your guys. |
Author: | peterb [ Sun Feb 18, 2018 6:55 am ] |
AEG163job wrote: Removing the bearing from the shaft is easy. Removing the outer shell from the transmission casing is much more fun (which you will now need to do since you've totalled the inner part! ![]() Easy. Just run a weld around inside of shell, it'll just fall out......into the trash. |
Author: | kiwiinwgtn [ Fri Feb 23, 2018 5:51 pm ] |
cgo wrote: Have used a small 2 jaw puller. Or read this; http://www.ausmini.com/forums/viewtopic.php?f=25&t=66729 Attachment: puller.JPG Sorry, too late. Nice to see my link in use, Pitty about photobucket issues |
