68mm pistons https://ausmini.com/forums/viewtopic.php?f=2&t=96830 |
Author: | Mattywill [ Fri Feb 16, 2018 7:56 pm ] |
Post subject: | 68mm pistons |
Hey all, the 1100 that was 60thou over has been pulled down and sent to the local engine recon guys. They say it’s outside tolerances and we either scrap the block or go 80 thou over with 68mm GR pistons. I’m keen to go with 68mm but my dad is concerned with overheating and reliability. Anyone built a 1098 with GR pistons please comment on reliability? It’s not a race engine but a weekend driver on club plates. Thanks Matt Sent from my iPhone using Tapatalk |
Author: | aaron [ Fri Feb 16, 2018 8:25 pm ] |
Post subject: | Re: 68mm pistons |
68mm will need more than just a rebore. However, 80" or 100" over are perfectly fine. Don't go overboard on cam and head mods and you wil have a nice Weekend driver. |
Author: | drmini in aust [ Fri Feb 16, 2018 9:03 pm ] |
I have built 4 motors with 68 mm bore. 68 mm needs the bores offset, a 1275 gasket and some water holes moved to suit it. Bore it to +080 or +100, no such problems. |
Author: | Mattywill [ Fri Feb 16, 2018 9:18 pm ] |
Thanks guys, 12g295 head., cooper ground crank? LCB extractors, hi lift rockers. I’d like some more advice around boring the block? Offset cylinders? Sent from my iPhone using Tapatalk |
Author: | Quick 850 [ Fri Feb 16, 2018 9:42 pm ] |
Mattywill wrote: Hey all, the 1100 that was 60thou over has been pulled down and sent to the local engine recon guys. They say it’s outside tolerances and we either scrap the block or go 80 thou over with 68mm GR pistons. I’m keen to go with 68mm but my dad is concerned with overheating and reliability. Anyone built a 1098 with GR pistons please comment on reliability? It’s not a race engine but a weekend driver on club plates. Hi mate i std bore block if you need one call me 0428410636Thanks Matt Sent from my iPhone using Tapatalk Sent from my SM-G930F using Tapatalk |
Author: | drmini in aust [ Sat Feb 17, 2018 5:22 am ] |
If boring to +.100" or less just straight bore it. |
Author: | Mattywill [ Sat Feb 17, 2018 6:54 am ] |
Ok guys thanks heaps. We should be able to go again. We have a few spares if it’s completely shot. Sent from my iPhone using Tapatalk |
Author: | drmini in aust [ Sat Feb 17, 2018 7:16 am ] |
Note that 68mm is +.133" oversize from standard 998 and 1098 bore. So boring to +.080" and +.100" is no big deal. |
