https://ausmini.com/forums/
Carb Drills
https://ausmini.com/forums/viewtopic.php?f=2&t=96829
Author:  Ian_B [ Fri Feb 16, 2018 7:19 pm ]
Post subject:  Carb Drills
Wondered when they would arrive or if they would but they are here today Thanks Kev . Trip tomorrow with Rob to pick up a spare 1100s block.
Author:  drmini in aust [ Fri Feb 16, 2018 8:49 pm ]
Post subject:  Re: Carb Drills
US post to Oz ain't fast. My set of drills took over 3 weeks.
But at least the sizes supplied are right, unlike the POS set of Chinese ones I got on eBay. Sizes missing and others double supplied.
Author:  Ian_B [ Sat Feb 17, 2018 12:08 pm ]
1100S block Standard bore 300 bucks .Looking out for a spare crank and rods now.
Are those new CAM6232 any good for stroking destroking and wedging ?
Author:  drmini in aust [ Sat Feb 17, 2018 12:23 pm ]
They have rolled fillet radii on all the journals. Ask GR. ;)
Author:  Ian_B [ Sat Feb 17, 2018 12:36 pm ]
I think they may be OK in standard form only?? I understand that fillet radius is very important for strength and is where they will fracture if it isnt right
Author:  drmini in aust [ Sat Feb 17, 2018 1:02 pm ]
You can grind the crankpins down by 1/8" for S rods, at standard stroke, using a standard ground fillet radius. But when/if you offset grind to stroke it the radii will clash. Rolled fillets are smaller diameter than the crankpin is. This will create stress points.
Author:  Ian_B [ Sat Feb 17, 2018 1:21 pm ]
Wow thats a trap.I guess for a standard stroke road car or a racer on a budget they are a good option.
Might wait for a good 1100s crank to surface .
Author:  kiwiinwgtn [ Fri Feb 23, 2018 6:56 pm ]
What crank would you use if you are going to off set grind. Also do you need to start off with a standard crank.
Author:  Ian_B [ Fri Feb 23, 2018 7:15 pm ]
The closer to standard the more stroke can be achieved maintaining standard S big ends.
I presented GR with a standard all over 1100S crank that was in a mates cupboard for many years.
It came back wedged balanced and stroked to 84mm standard S pins standard mains
The fillet radius is great also .Great job from Spero and Graham.
Author:  drmini in aust [ Fri Feb 23, 2018 7:31 pm ]
I did the same. Except I wedged it myself.
Look for a 12G1505 crank. Preferably STD size or close to. Crack test it before spending any $$$. ;)
Author:  mickmini [ Fri Feb 23, 2018 8:06 pm ]
Spiro is a legend :-)
