indicators stopped working. https://ausmini.com/forums/viewtopic.php?f=2&t=96817 |
Author: | carter [ Thu Feb 15, 2018 11:10 am ] |
Post subject: | indicators stopped working. |
my indicators have all of a sudden stopped working...... everything else works fuses are ok where does the power come to the indicators from? |
Author: | gtogreen1969 [ Thu Feb 15, 2018 12:56 pm ] |
Post subject: | Re: indicators stopped working. |
carter wrote: my indicators have all of a sudden stopped working...... everything else works fuses are ok where does the power come to the indicators from? You haven't said what mini but if its on your 67 S then the power it taken from a green wire on the fuse box, through the flasher can then on to the indicator switch. ![]() |
Author: | carter [ Thu Feb 15, 2018 1:26 pm ] |
sorry its not on my s its on my 75 Leyland. I have power on one side of my plug that goes to my flasher can but there is no power at my indicator stalk and its been too long to remember where the power comes from. |
Author: | gtogreen1969 [ Thu Feb 15, 2018 1:58 pm ] |
carter wrote: sorry its not on my s its on my 75 Leyland. I have power on one side of my plug that goes to my flasher can but there is no power at my indicator stalk and its been too long to remember where the power comes from. The power comes from a green wire on the fuse box into the flasher can. Then coming out of the flasher can as a Light Green / Brown wire which then feeds the indicator stalk. |
Author: | Convertible Mini [ Thu Feb 15, 2018 3:02 pm ] |
If You have power at the + terminal on Flasher unit, Bridge between the '+' and 'L' terminals on the flasher unit itself and the indicators should work but not flash. If this works you Flasher unit is Cactus. |
Author: | carter [ Thu Feb 15, 2018 4:14 pm ] |
Yea I have power at one wire st the flasher can but that’s where it stops |
Author: | carter [ Thu Feb 15, 2018 7:04 pm ] |
You were right convertablemini flasher unit was catctus. Thanks everyone for your help |
