https://ausmini.com/forums/
BMC Hydrolastic Pump Rebuild
https://ausmini.com/forums/viewtopic.php?f=2&t=96810
Author:  cooperess [ Wed Feb 14, 2018 1:21 pm ]
Post subject:  BMC Hydrolastic Pump Rebuild
I am in the process of rebuilding the above.
Can anyone help me in finding replacement clear tubing as my tubing is brittle and not clear.
Author:  Bill B [ Wed Feb 14, 2018 4:21 pm ]
Post subject:  Re: BMC Hydrolastic Pump Rebuild
Have you tried hydraulic repairers?
A business called Industrial Fittings Sales Ingleburn, NSW does lots of tubing and brass fitting etc. They list high pressure semi-rigid hose in black or natural (recommended PSI is 625) including 3/16, 1/4 and 5/16inch in cut lengths.
Author:  winabbey [ Wed Feb 14, 2018 4:32 pm ]
I agree. Try Enzed or Pirtek.
Actually I recently purchased some pressure hose for my hydro pump system at Bunnings. I have an air hose fitting on one end and use it to extract the fluid from a pumped up system into a container. While it's rated at 120psi it doesn't need to handle pressure that high. Depending on what part of the pump system your hose is located it may need to support a higher pressure.
https://www.bunnings.com.au/kinetic-16m ... e_p4920233
Author:  Bill B [ Wed Feb 14, 2018 6:30 pm ]
Is Ended still in business?
Campbelltown Pirtek has at least one member who understands hydrolastic and has helped customers build their own pumps as well as repair displacers.
Author:  i got a mini [ Wed Feb 14, 2018 8:04 pm ]
my brother replaced his bubbaclubby on hear pm him and ask him he could possible help you out
