Metal clamping method https://ausmini.com/forums/viewtopic.php?f=2&t=96705 |
Author: | auberge [ Mon Jan 29, 2018 9:10 am ] |
Post subject: | Metal clamping method |
Has anybody come across this method of joining sheet metal prior to welding in inaccessible places where you can't easily clamp (hopefully pic is attached)? Apart from seeing it on a mini restoration site I have also seen it used on the tv show Fantomworks. I am not sure how the studs are inserted, maybe with a special tool. Greg |
Author: | timmy201 [ Mon Jan 29, 2018 9:46 am ] |
Post subject: | Re: Metal clamping method |
They are called celco pins/clamps. There are lots of how-to and videos on the net |
Author: | auberge [ Mon Jan 29, 2018 10:09 am ] |
Thanks. I found them under Cleco pins. |
Author: | 9YaTaH [ Mon Jan 29, 2018 2:19 pm ] |
Widely used in the aircraft industry.... |
Author: | Kennomini [ Mon Jan 29, 2018 7:21 pm ] |
You can also use self tapping screws to hold panels together, seems dodgy but gives you the same finish and is way cheaper. |
