It is currently Wed Jul 16, 2025 6:58 am
PostPosted: Sat Jan 27, 2018 9:12 am
people who fit kwik-shifts to fairly-worn gearboxes & then think they can slam the gears thru quicker are what kills gearboxes
people please understand that if your gearbox is quite old (even tho it seems to work ok still) then you fit a kwik-shift (of whatever brand) & then if you think (for some reason) that because now you have a quick-shift that you can "Race" the gears,,,, "You" are wrecking your gearbox
calm down, take a chill pill, understand some physics here & you`ll be fine
a nice newly build (properly) gearbox with a quick-shift fitted (correctly) & used correctly will not kill your gearbox
it`s come to the point where i`ve been reading & hearing so many people tell me that the Kwik-shfits destroy gearboxes----> """RUBBISH""",,, absolute total rubbish.
Also---> some kwik-shifts (when fitted) may need a little extra clearance on the old gear-shift housing to allow the extra throw to clear the old shift-housing,,, some don`t,,, just be aware & do whats needed when fitting it & all will be well... but if you`re gearbox is 20-years old, please don`t blame the kwik-shift & spread utter crap about them.
i understand some people don`t like them , that`s fine, i don`t like "all" of them either, but some are sweet, when set-up well , a good box,,, then they`re great.
sorry, just getting sick & tired of hearing/reading it... :-)
ok, vent over :-)
PostPosted: Sun Jan 28, 2018 1:20 pm
The "quick shifts" that I have seen are only a different ratio of the gear knob to gear lever pivot in the remote housing to the ball end of the lever.
All this does is change the travel distance of the gear knob.
You could just pull the old gear lever faster for the same effect. :D
Don't the synchro rings still have to "match" the gear speeds so that the dogs can engage. Forcing them to engage before the speeds are matched can't be good for the dogs, hence chipped dog teeth. Or am I not seeing something obvious :|
PostPosted: Sun Jan 28, 2018 2:20 pm
I'm clueless when it comes to "quick shifts". How/ what do they do? It's never occurred to me my shift is "slow" (well sorted newish remote setup)...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sun Jan 28, 2018 2:27 pm
They are also known as "short shifts". They reduce the throw needed to change gears by changing the leverage ratio of the pivot point.
E.g.
http://minisport.com.au/mini-kad-quick- ... alloy-type
http://minisport.com.au/mini-kad-quick- ... or-reverse
PostPosted: Sun Jan 28, 2018 3:24 pm
Do they make a noticeable difference? By the time I clutch in and out I've already changed the gear??
67 Deluxe
Dry suspension
PostPosted: Sun Jan 28, 2018 4:27 pm
Said everyone who can drive a manual :lol:
WD40'll fix it!
If it don't, use a big hammer!
PostPosted: Sun Jan 28, 2018 5:03 pm
I fitted a KAD shifter when I converted from the remote box to rod change The KAD rod change one is about the only one of these 'quick' shifters worth using as far as I can tell. With a synchro gearbox shift speed will always be limited by the syncros, and as other have said shortening the throw of the shifter doesn't allow the shift to be made any faster... In the case of the rod change, the standard shifter has a pretty long throw relative to the remote, but with the 'quickshift' it is nicer to drive than the remote was, even with all the worn bushes etc. replaced.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Sun Jan 28, 2018 6:25 pm
Ive got the pudding stirrer shift down to almost 25 seconds.
Sent from my SM-G900I using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
PostPosted: Sun Jan 28, 2018 7:56 pm
Haha, good one :lol:
PostPosted: Mon Jan 29, 2018 9:22 am
:mrgreen: :mrgreen: :mrgreen:
LOL!
Zulu...
1967 mini Cooper S
PostPosted: Mon Jan 29, 2018 12:43 pm
Easy and quick to make an Oz quickshift.. cut 40mm or more off the shift lever and rethread it.;)
PostPosted: Mon Jan 29, 2018 1:06 pm
I have trouble reaching the gearlever as it is. Probably because the seat has to be all the way back to fit my legs in.
PostPosted: Mon Jan 29, 2018 4:31 pm
Actually I think that's the main reason to buy a Quikshift.
I have a Paddy Hopkirk recliner with custom mounts, a lowered steering column and smaller steering wheel. I used to find it difficult to reach first when strapped in. With the KAD Quikshift fitted the knob is about a hand width from the rim of the wheel.
While I couldn't really say shifts are quicker, I do find the reduced travel much more comfortable....
Cheers, Ian
PostPosted: Fri Feb 02, 2018 8:37 am
Cheers, Ian
Well done Ian. It's not about the speed, it's about the reduced travel.
Dalmeny
PostPosted: Fri Feb 02, 2018 10:58 am
Maybe they need a universal rename to ShortShifts
Nick
