It is currently Wed Jul 16, 2025 7:28 am
PostPosted: Thu Feb 15, 2018 11:10 am
my indicators have all of a sudden stopped working...... everything else works fuses are ok where does the power come to the indicators from?
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Thu Feb 15, 2018 12:56 pm
You haven't said what mini but if its on your 67 S then the power it taken from a green wire on the fuse box, through the flasher can then on to the indicator switch.
PostPosted: Thu Feb 15, 2018 1:26 pm
sorry its not on my s its on my 75 Leyland. I have power on one side of my plug that goes to my flasher can but there is no power at my indicator stalk and its been too long to remember where the power comes from.
1970 mini k
1975 leyland
PostPosted: Thu Feb 15, 2018 1:58 pm
The power comes from a green wire on the fuse box into the flasher can. Then coming out of the flasher can as a Light Green / Brown wire which then feeds the indicator stalk.
PostPosted: Thu Feb 15, 2018 3:02 pm
If You have power at the + terminal on Flasher unit, Bridge between the '+' and 'L' terminals on the flasher unit itself and the indicators should work but not flash. If this works you Flasher unit is Cactus.
"Let us remove your "SHORTS"
PostPosted: Thu Feb 15, 2018 4:14 pm
Yea I have power at one wire st the flasher can but that’s where it stops
1970 mini k
1975 leyland
PostPosted: Thu Feb 15, 2018 7:04 pm
You were right convertablemini flasher unit was catctus. Thanks everyone for your help
1970 mini k
1975 leyland
Users browsing this forum: acarseldine, Bing [Bot] and 57 guests
