https://ausmini.com/forums/
Curley UK - anyone used them?
https://ausmini.com/forums/viewtopic.php?f=2&t=96676
Author:  ten_sim [ Wed Jan 24, 2018 6:55 pm ]
Post subject:  Curley UK - anyone used them?
https://curleyuk.com/classic-mini/... thinking about using one of their dash setups in my Clubman (I assume, probably incorrectly, that the sizing for a 'classic' mini would be the same as a Clubman in the dash department?)
Author:  1071 S [ Wed Jan 24, 2018 8:25 pm ]
Post subject:  Re: Curley UK - anyone used them?
Well Curley used have a reputation as one of the premier carbon fibre supplier in the UK.... They did lots of Mini stuff..
AFAICT the dimensions of the Clubbie and Roundy dash are identical.
Cheers, Ian
Author:  drmini in aust [ Thu Jan 25, 2018 9:16 am ]
If you pull all the padding off a clubby dash it's a roundy dash underneath with a few extra holes.
Author:  Convertible Mini [ Thu Jan 25, 2018 7:28 pm ]
Fitting a Dash without padding in a street car like a leyland Mini that had Padding will make the car non compliant. Check ADRs of the car's year before you do it.
Author:  drmini in aust [ Fri Jan 26, 2018 4:51 am ]
Should be legal on a 1971 clubby my son is building with a MK 2 binnacle. As a 71 S didn't have it.
Author:  timmy201 [ Fri Jan 26, 2018 6:30 am ]
ADR 21 (instrument panels) came into effect on 1st Jan 1973.
https://infrastructure.gov.au/roads/mot ... _adrs.aspx
