https://ausmini.com/forums/
Popping out of 3rd gear
https://ausmini.com/forums/viewtopic.php?f=2&t=96658
Author:  mystq [ Sat Jan 20, 2018 5:04 pm ]
Post subject:  Popping out of 3rd gear
Hi all,
If I drive along in 3rd for a bit then back off it jumps out of 3rd, could someone please tell me what options I have. And thank to the people who have helped me out already, great forum :D
Author:  Goldbrocade_62 [ Sat Jan 20, 2018 5:57 pm ]
Post subject:  Re: Popping out of 3rd gear
Check engine mounts steadies gearbox mounts but more probably internal
Author:  gtogreen1969 [ Sat Jan 20, 2018 6:01 pm ]
If its a rod change box then it could be worn or loose parts in the shifting mechanism. A loose gearlever, worn internal yoke or broken rubber mounts can cause it to pop out of gear.
Author:  drmini in aust [ Sat Jan 20, 2018 6:02 pm ]
Any of the following:
Wear of 3rd gear and synchro hub drive dogs,
weak synchro hub springs,
Worn 3-4 selector fork,
Weak detent spring(s),
End float in 3rd gear.
Author:  gtogreen1969 [ Sat Jan 20, 2018 6:07 pm ]
Here is a bit of info on the rod change if you also have a sloppy gearchange. https://www.moke.com.au/in-the-garage/g ... gearchange
Hope its not an internal box issue. Good luck.
Author:  Harley [ Sat Jan 20, 2018 6:33 pm ]
Mine did that after fitting a new rubber boot / gaiter thingy to the rod change unit.
The new one was too long and pushing against the collar with the roll pins in it. :lol:
Author:  Quick 850 [ Sun Jan 21, 2018 10:48 am ]
mystq wrote:
Hi all,
It will be the dog teeth on the gear and sink hub .
Sent from my SM-G930F using Tapatalk
Author:  goodie [ Mon Jan 22, 2018 7:48 am ]
In your post that you put up when you brought the car you said that it came with receipts , is there any paperwork amongst it that shows that any thing had been done to the gearbox?
Author:  John Smidt [ Mon Jan 22, 2018 11:23 am ]
If it is a rod change, check 1) gear lever, 2) connecting coupling 3) gear Lever locating pin in selector housing.
If it is not a Rod Change type check the selector toggles, make sure they are aligned correctly and they are tight,
The above may fix your problem if not then my guess is it is internal, which may have been caused by problems mentioned above
