Borrow Flywheel Puller https://ausmini.com/forums/viewtopic.php?f=2&t=96656 |
Author: | cooperess [ Fri Jan 19, 2018 10:10 pm ] |
Post subject: | Borrow Flywheel Puller |
I'm located at Brandy Hill NSW and looking to borrow a flywheel puller. If anyone close by is willing to assist please let me know. |
Author: | peterb [ Sat Jan 20, 2018 9:56 am ] |
Post subject: | Re: Borrow Flywheel Puller |
A bit of 1/2'' plate and some 3/8'' threaded rod, make your own. That way it'll guarantee you that nothing will go wrong with clutch etc.........you're prepared for it. ( Murphys law number 27.5) |
Author: | deluxe67 [ Sat Jan 20, 2018 11:27 am ] |
Make sure you have something to fit into the crank bolt hole to protect the threads if you use a centre bolt! |
Author: | TK [ Sun Jan 21, 2018 10:48 am ] |
Take the keyway out and put the bolt back in. don't do it all the way up. |
Author: | DavidE [ Sun Jan 21, 2018 4:06 pm ] |
TK wrote: Take the keyway out and put the bolt back in. don't do it all the way up. You're referring to the key, aren't you. Not the keyway. |
