https://ausmini.com/forums/
Fresh air blank
https://ausmini.com/forums/viewtopic.php?f=2&t=96641
Author:  MiniMat [ Wed Jan 17, 2018 5:00 pm ]
Post subject:  Fresh air blank
Question regarding the circular fresh air vent blank in front of the driver. Is the colour meant to be body colour and was there a rubber seal installed?
Cheers mini people!
Mat
Author:  Bill B [ Wed Jan 17, 2018 5:36 pm ]
Post subject:  Re: Fresh air blank
Do you mean the 5 inch diameter disc facing into the engine bay with 4 self-tapping screws?.
If so, it was satin black and had a mastic material used to seal it - no rubber gasket/seal.
Author:  DavidE [ Wed Jan 17, 2018 5:45 pm ]
However, most recently, I used some self-adhesive rubber of the right width and depth to suit the trough on the outside diameter and it worked treat. I was easily able to work it to follow the circumference.
Author:  Bill B [ Wed Jan 17, 2018 5:50 pm ]
Yes, David.
I think I have also done the same with self-adhesive rubber foam.
But... think "Concourse", David! Think "Concourse".
Author:  DavidE [ Wed Jan 17, 2018 6:17 pm ]
Yes, David.
Bill,
If l'inspecteur general des concours d'elegance is able to see what lies behind the installed blanking plate, then I'll have to cop it.
I'm actually more concerned about his specialist glass-markings interrogator, because there's nothing I can hide there.
Cheers!
Author:  MiniMat [ Wed Jan 17, 2018 7:11 pm ]
Thanks all!
To be clear, ultimately I wanted to know the colour before sending the shell down for painting!
Concorse... I don't think so... :oops:
While I'm at it, the colour of the master cylinder base plate?
Author:  coatsie [ Wed Jan 17, 2018 9:19 pm ]
Satin black.
Author:  MiniMat [ Thu Jan 18, 2018 7:33 am ]
Thanks Richard.
When I was using thinners on mine to clean it up, it looked like it could have been painted Silver at some stage.
