https://ausmini.com/forums/
Valve stem seals/o-rings
https://ausmini.com/forums/viewtopic.php?f=2&t=96620
Author:  hpal [ Sat Jan 13, 2018 12:29 pm ]
Post subject:  Valve stem seals/o-rings
Rebuilding the 202 head and have put new valve guides in with a groove to take conventional valve stem seals. What do the small o-rings which came in my gasket set do? Do I need them when I run the other seals? Thanks
Author:  hpal [ Sat Jan 13, 2018 12:38 pm ]
Post subject:  Re: Valve stem seals/o-rings
Author:  minimanic [ Sat Jan 13, 2018 1:27 pm ]
The O ring seals don't get used when fitting the S type (on the right of pic).
You can chuck the o rings if you want, they don't work very well, the S type is the way to go.
Always check the caps don't hit them if you are using long collet valves and high lift cam.
Author:  Scoop [ Sat Jan 13, 2018 1:44 pm ]
And also make sure the groove fits the seal. I have had to machine off part of the guide to allow the seal to fit before.
Author:  peterb [ Sun Jan 14, 2018 6:33 am ]
Don't the O rings only fit early mini's with the long collet groove?
Author:  drmini in aust [ Sun Jan 14, 2018 7:12 am ]
Yes. I would fit them in, they help stabilize the early collets.
I have used the 1275 seals on plain smallbore guides by smearing some 262 Loctite on the guides.
Author:  hpal [ Sun Jan 14, 2018 7:56 am ]
Are the 1275 seals different?
Where exactly do the o-rings fit? cheers
Author:  peterb [ Sun Jan 14, 2018 9:10 am ]
You fit them in collet....sort of.
Author:  winabbey [ Sun Jan 14, 2018 9:38 am ]
Part 19 in this exploded diagram of a 998 head.
Author:  drmini in aust [ Sun Jan 14, 2018 10:31 am ]
You fit the O ring into the valve stem groove when spring is compressed, then fit both collets on top of it.
Only used on early valves with the wide collet groove.
Author:  hpal [ Sun Jan 14, 2018 10:53 am ]
Thanks guys
Author:  hpal [ Sat Jan 27, 2018 1:39 pm ]
Copper side up?
Author:  drmini in aust [ Sat Jan 27, 2018 4:53 pm ]
Generally yes.
Copper gaskets aren't as good as in the old days, if you get water leakage fit a BK450 composition one instead.
Author:  hpal [ Sat Jan 27, 2018 6:40 pm ]
thanks mate, I have another gasket (looks like a black and silver one) perhaps I should just fit that?
Author:  drmini in aust [ Sat Jan 27, 2018 6:49 pm ]
Try it.
