https://ausmini.com/forums/
support bracket for C.S extractors 1970
https://ausmini.com/forums/viewtopic.php?f=2&t=96583
Author:  p7676 [ Sat Jan 06, 2018 8:08 pm ]
Post subject:  support bracket for C.S extractors 1970
Do you need a support bracket on the exhaust other than the first bracket on the rear subframe If there is a bracket I presume it would bolt to the engine or gearbox. Other cars that I have worked on usually have a bracket at the front.Seems like a big load on the on the extractors without a bracket.Whish I knew more about Minis.
Thanks
Author:  drmini in aust [ Sun Jan 07, 2018 6:40 am ]
Post subject:  Re: support bracket for C.S extractors 1970
Original S and Cooper 3-1 headers had a bracket onto the remote shift housing. There is an angled lug there for it. Not seen the bracket for years.
If replaced with a modern LCB there is a flat bracket to the RH diff side cover, bottom hole.
Author:  deluxe67 [ Sun Jan 07, 2018 8:50 am ]
Hi Doc, are those brackets essential? I've been running my car years with no front bracket (there isn't one on my LCB) with no issues. Should I consider putting one on? (would be a major PITA...)
Author:  drmini in aust [ Sun Jan 07, 2018 9:25 am ]
You can just get away with it if you have a remote shift box and good mounts and steady rubbers. But I say run em if ya go em.
But it's essential to use a front bracket on rodchange cars.
Author:  deluxe67 [ Sun Jan 07, 2018 10:04 am ]
Thanks Doc. I have the remote type and good mounts, rubbers etc. The whole lot seems very secure. (only a couple of mm clearance between the pipe and remote in places but it doesn't rub). I'll stick with what I've got...
Author:  Bubbacluby [ Sun Jan 07, 2018 6:33 pm ]
Anyone got a pic of what the actual bracket looks like ?
Author:  winabbey [ Sun Jan 07, 2018 9:25 pm ]
#5 in this exploded parts diagram. It attaches to the side of the remote gear extension using bolt #7 and washer #8.
Author:  Bubbacluby [ Sun Jan 07, 2018 10:09 pm ]
Thanks Doug.
Looks like its an exhaust clamp as well as a mount?
Author:  drmini in aust [ Mon Jan 08, 2018 6:04 am ]
Yes it is similar to the flat clamps on a maniflow LCB but bigger diameter.
Author:  winabbey [ Mon Jan 08, 2018 6:33 am ]
Somerford have a very similar version. I think the Mini parts places or an exhaust shop could supply as well.
http://www.somerfordmini.co.uk/eshop/in ... s_id=13935
