It is currently Wed Jul 16, 2025 10:15 pm
PostPosted: Sat Jan 06, 2018 8:08 pm
Do you need a support bracket on the exhaust other than the first bracket on the rear subframe If there is a bracket I presume it would bolt to the engine or gearbox. Other cars that I have worked on usually have a bracket at the front.Seems like a big load on the on the extractors without a bracket.Whish I knew more about Minis.
Thanks
PostPosted: Sun Jan 07, 2018 6:40 am
Original S and Cooper 3-1 headers had a bracket onto the remote shift housing. There is an angled lug there for it. Not seen the bracket for years.
If replaced with a modern LCB there is a flat bracket to the RH diff side cover, bottom hole.
PostPosted: Sun Jan 07, 2018 8:50 am
Hi Doc, are those brackets essential? I've been running my car years with no front bracket (there isn't one on my LCB) with no issues. Should I consider putting one on? (would be a major PITA...)
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sun Jan 07, 2018 9:25 am
You can just get away with it if you have a remote shift box and good mounts and steady rubbers. But I say run em if ya go em.
But it's essential to use a front bracket on rodchange cars.
PostPosted: Sun Jan 07, 2018 10:04 am
Thanks Doc. I have the remote type and good mounts, rubbers etc. The whole lot seems very secure. (only a couple of mm clearance between the pipe and remote in places but it doesn't rub). I'll stick with what I've got...
67 Deluxe
Dry suspension
PostPosted: Sun Jan 07, 2018 6:33 pm
Anyone got a pic of what the actual bracket looks like ?
PostPosted: Sun Jan 07, 2018 9:25 pm
#5 in this exploded parts diagram. It attaches to the side of the remote gear extension using bolt #7 and washer #8.
PostPosted: Sun Jan 07, 2018 10:09 pm
Thanks Doug.
Looks like its an exhaust clamp as well as a mount?
PostPosted: Mon Jan 08, 2018 6:04 am
Yes it is similar to the flat clamps on a maniflow LCB but bigger diameter.
PostPosted: Mon Jan 08, 2018 6:33 am
Somerford have a very similar version. I think the Mini parts places or an exhaust shop could supply as well.
http://www.somerfordmini.co.uk/eshop/in ... s_id=13935
Users browsing this forum: Bing [Bot] and 107 guests
