Fox injection Heritage Throttle Body https://ausmini.com/forums/viewtopic.php?f=2&t=96538 |
Author: | mini_man_90 [ Mon Jan 01, 2018 11:30 am ] |
Post subject: | Fox injection Heritage Throttle Body |
https://foxinjection.com/products/herit ... 9403888653 Has anybody tried something like this? Or know of anyone who has? I'm considering it somewhere down the track, but know nothing a out it. Cheers. |
Author: | timmy201 [ Mon Jan 01, 2018 12:06 pm ] |
Post subject: | Re: Fox injection Heritage Throttle Body |
Fuel injection on 5 port mini engines is pretty tricky to get right due to the siamese ports, and for a carburettor car you need to add a new fuel system with high fuel pressure, return lines, all the sensors to get the ECU to work and you'd add in a new ignition system at the same time. There is one here that had a similar weber style injection with a downdraft setup. You might need to register to view the posts. http://mk1-forum.net/viewtopic.php?f=6&t=7090&start=130 He also does some videos on youtube https://www.youtube.com/watch?v=WYiNOAEn96Q |
Author: | mini_man_90 [ Mon Jan 01, 2018 2:05 pm ] |
That's basically what I thought was involved. I'm running a morris 1500cc motor with custom intake manifold, already running twin 45mm dcoe webers. I also have a facet type electric fuel pump setup, and I have recently completely overhauled my ignition setup with new electronic distributor, new high power coil, new leads and plugs too... I was looking at it thinking some of the fabrication work is already done, but it still sounds like a fair bit of work and knowing what you're doing to get it done right. |
Author: | timmy201 [ Mon Jan 01, 2018 2:25 pm ] |
You’ll need a fuel pump rated for fuel injection as you need much higher pressure than for a carb system. You normally have a fuel pressure regulator and a return fuel line back to the tank. For the ignition system I’d ditch the distributor all together and use a modern coil pack and a trigger wheel for crank position sensing |
