https://ausmini.com/forums/
Sounds like loose wheel nuts :-/
https://ausmini.com/forums/viewtopic.php?f=2&t=96537
Author:  brett [ Sun Dec 31, 2017 10:54 am ]
Post subject:  Sounds like loose wheel nuts :-/
Hi guys. Got a weird sound from the cooper S its got a grinding noise. And almost like a loose front wheel sound but no vibration from the wheel I have checked them and they are tight... any sugesstions. Thinking bearings...
Author:  deluxe67 [ Sun Dec 31, 2017 1:12 pm ]
Post subject:  Re: Sounds like loose wheel nuts :-/
Get a mate, jack it up and wriggle the wheels. Look/ feel for things/ play that shouldn't be there. Anything drastic will be immediately obvious....
Author:  brett [ Sun Dec 31, 2017 2:10 pm ]
yeah, I ended up doing that. and turned out the 4 Allen screws were loose on the hub
Author:  drmini in aust [ Sun Dec 31, 2017 3:04 pm ]
A mate had the same problem this week.
I use an impact driver on them. ;)
Author:  brett [ Sun Dec 31, 2017 3:11 pm ]
I just used a ratchet. Hopefully thats good enough... It's been loose for quite a while. I just kept removing the wheel nuts and putting them on.. it seems to do the trick for a while... Hopefully this is the actual fault.
Author:  drmini in aust [ Sun Dec 31, 2017 7:27 pm ]
We fitted a new drive flange but the old one looks fine.
