https://ausmini.com/forums/
oil cooler CS 1970
https://ausmini.com/forums/viewtopic.php?f=2&t=96536
Author:  p7676 [ Sat Dec 30, 2017 7:27 pm ]
Post subject:  oil cooler CS 1970
Just fitting gear onto engine, the clearance between oil cooler and starter motor is 4mm is that enough?
Also 2 holes above starter motor 5/16, approx. 70 mm apart what goes there ?
Thanks Allen
Author:  Goldbrocade_62 [ Sat Dec 30, 2017 7:42 pm ]
Post subject:  Re: oil cooler CS 1970
Pretty sure all is tight ,are you talking about in the transfer housing wheresolenoid would be
Author:  p7676 [ Sat Dec 30, 2017 7:46 pm ]
probably but the new solenoid is smaller between hole centres
Author:  Goldbrocade_62 [ Sat Dec 30, 2017 8:02 pm ]
The solenoid is screwed to a mounting plate which bolts to the housing
Author:  p7676 [ Sat Dec 30, 2017 8:58 pm ]
TY
Author:  simon k [ Sun Dec 31, 2017 9:51 am ]
doesn't sound right.... I don't use my oil cooler anymore, and have a Gemini starter motor, but I reckon there was more clearance than that...
Author:  Mick [ Sun Dec 31, 2017 11:20 am ]
Its pretty close, but doesn't touch.
Author:  deluxe67 [ Sun Dec 31, 2017 1:15 pm ]
I have a relationship problem with oil coolers so I stopped using the things. Except for originality purposes not sure if they are even necessary?
Author:  cooperess [ Sun Dec 31, 2017 4:22 pm ]
Aren't they used in performance cars!
Author:  Goldbrocade_62 [ Sun Dec 31, 2017 5:25 pm ]
When the S came out oils was rubbish times have changed oil is much better these days
