It is currently Tue Jul 08, 2025 5:41 am
 Post subject: Starter Solenoids
PostPosted: Thu Dec 28, 2017 12:17 pm
I had an old Lucas Starter Solenoid go west on me a little while back, and so I sought out a new one to replace it. I picked up a "Lucas" branded solenoid in new in the box and installed it a few weeks later. After a very short amount of time (especially given the limited opportunities I have had to drive the car) the solenoid has again failed. This solenoid is available from all the mini websites, and appears to be sold in identical packaging
Now I know that there are a number of cheap chinese solenoids available, and that they are intrinsically unreliable, however I thought I may have a certain amount of trust in a Lucas branded solenoid. The question is, if I am after a new solenoid, where is the best place to find a reliable Lucas solenoid?
 Post subject: Re: Starter Solenoids
PostPosted: Thu Dec 28, 2017 12:32 pm
I would look for one of the Lucas NOS parts sellers. There are a few if you search.
Anthony Pearson is based in S.A. and regularly has a stall at Bendigo and Ballarat Swap Meets. He usually stocks a lot of NOS Lucas parts.
http://www.classicandvintagebulbs.com/
Also Danny & Sandra Lee located in Hallam, Vic.
http://www.oldlucas.com.au/
PostPosted: Thu Dec 28, 2017 1:18 pm
Sometimes I think you're better off just buying used bits from a Mini specialist. I've never had one fail and you can probably pick an old one up for not much....
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Thu Dec 28, 2017 1:30 pm
Which type was it? Mk1 push button or Mk2 / Clubby
PostPosted: Thu Dec 28, 2017 1:59 pm
Thanks all, it was the the later Mk2/Clubby style. Deluxe, you're right. I don't think I've ever killed an original one, but I got caught up in the pretty new plating look of the replacement solenoids in the nice packaging...ha ha
I'll take a look at the NOS sources, thanks Doug.
PostPosted: Thu Dec 28, 2017 2:20 pm
gtogreen,
Mate, none of my Mk 1's had the push button. Think maybe that was a really early feature? Where do you live Mick? Here in Melbourne there's a few places with good 2nd hand bits...
67 Deluxe
Dry suspension
PostPosted: Thu Dec 28, 2017 2:28 pm
I'm up in Sydney. Usually I would have a few spare old ones as well. Alas I have reduced my spares pile considerably :lol:
PostPosted: Thu Dec 28, 2017 2:53 pm
Bugger. I swapped over an original MK1 push button dated 1964 that was working properly only because my car was supposed to have the later style. I might have to keep the old one just incase.
