It is currently Tue Jul 08, 2025 9:30 am
PostPosted: Sat Oct 28, 2017 12:13 pm
I broke the window winder handle yesterday
Are the new Repro Handles that are for sale as good or better than original ones
Rather find a good original one but would fit a repro if they are good
1970 MK2 Cooper S
PostPosted: Sat Oct 28, 2017 1:21 pm
I bought some repro ones a few years back and they were terrible, thin and flimsy and bent before they'd break. I bought some recently and was amazed to find that they were at least as good, if not better than the originals. Not stupidly expensive either. There aren't many other repro parts I can say that about.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Sat Oct 28, 2017 3:30 pm
The original window and door interior handles were made for BMC by Wilmot Breeden and were used across the BMC range, and probably in many other vehicles. The BMC Australia manufactured items can be identified by a small dimple near the screw hole.
The dimple was added to the handle drawing effective April 1966 so any BMC cars built from that date would progressively have had the dimpled winder and door opener. Anyone absolutely fanatical on the originality of their car might like to check this. :)
It's usually the door handle that breaks because it cops a real beating by most owners and the plastic is now up to 50 years old. Luckily there are metal versions available that look almost the same when painted.
PostPosted: Sat Oct 28, 2017 5:11 pm
I've seen alloy versions...
PostPosted: Sat Oct 28, 2017 8:30 pm
I remember my Dad explaining that the dimple indicated the improved version of the handles (he was a body hardware engineer at BMC) as apparently the earlier ones were a serious problem as they tended to break. A lot of the earlier handles would have been replaced due to breakage or perhaps even as a matter of course by dealers in the first few years of the cars life.
PostPosted: Sun Oct 29, 2017 6:11 am
The original material was Black Kralastic K2938 (whatever that is), replaced by Black Lustrant, then Polycarbonate Black.
PostPosted: Sun Oct 29, 2017 7:15 am
https://plastics.ulprospector.com/datas ... -2938fsr-1
PostPosted: Sun Oct 29, 2017 10:27 pm
I have an assortment of both the plastic and diecast door handles if anyone needs them. I believe the metal ones came from Morris 1100s and/or MGBs but they look exactly the same (assuming the black paint is intact). I used the metal ones on my old S because the plastic ones are a bit weak.
PostPosted: Tue Oct 31, 2017 4:07 pm
we still have huge stock of New Genuine winder-handles & door-handles here
0407 135 656
Matt
PostPosted: Tue Oct 31, 2017 5:51 pm
Whats the cost Matt on the Window Winder Handle
1970 MK2 Cooper S
PostPosted: Tue Nov 07, 2017 4:40 pm
Do you have a price for a window winder handle
1970 MK2 Cooper S
PostPosted: Tue Nov 07, 2017 8:02 pm
Gundy, how many do you need - just one?
Tartanred (also Matt, but not THE Matt) ;)
PostPosted: Wed Nov 08, 2017 8:29 am
yes just 1
1970 MK2 Cooper S
PostPosted: Fri Dec 15, 2017 4:52 pm
I am still after a good original window winder handle
please PM me with a photo and price
Thanks
Marc
1970 MK2 Cooper S
PostPosted: Fri Dec 15, 2017 5:17 pm
Is there a reason you haven't taken Matt Read up on his offer?
