It is currently Wed Jul 09, 2025 6:25 am
 Post subject: Ultrasonic Cleaner
PostPosted: Sun Dec 24, 2017 6:05 pm
Anyone got one recommend one Comments please .
 Post subject: Re: Ultrasonic Cleaner
PostPosted: Tue Dec 26, 2017 12:45 pm
Nope new idea Have 2 kilos of white powder coming :lol: Citric Acid . Put towel in wash machine put carb parts on towell .Add hot water and let it go.This will work wonders .
PostPosted: Tue Dec 26, 2017 9:36 pm
On that note I've been told lemon juice and a toothbrush scrub works well on carbs too.
PostPosted: Wed Dec 27, 2017 12:09 pm
Thanks Kev will post results as long as police dont intercept my white powder lol :lol:
PostPosted: Wed Dec 27, 2017 1:02 pm
We use ultrasonics in my work. The key is a combination of the carrier solution and the ultrasonic action. The main advantage is it can loosen areas to small to access with a brush.
PostPosted: Wed Dec 27, 2017 6:38 pm
Just to add , i remember reading somewhere ( may of been here ) that "boiling" alloy parts in lemon juice works good as well , i was going to try it ages ago on an 1/12" carby to test the theory, brought the lemon juice and they are still sitting on the shelf in the shed . :oops: :lol: .
PostPosted: Thu Dec 28, 2017 8:28 am
Same here. They are fine for small fiddly mechanisms, etc, but not much chop on anything heavy.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Sat Dec 30, 2017 1:49 pm
New idea that works Use the Docs method I suggest 1 hour not two My Dellortos turned grey then use this stuff from Repco Wow
PostPosted: Sat Dec 30, 2017 5:27 pm
What kitchens are for
PostPosted: Sat Dec 30, 2017 6:48 pm
Highly recommend this autosol stuff on its own Magic results
Docs method uses an alkaline degreaser It cleans the crap out of them but they went near black Fret not Chemistry says an acid will reverse that and yes it does.My carbs are now beautiful.I also used an acidic household cleaner to finish off.
