Ultrasonic Cleaner https://ausmini.com/forums/viewtopic.php?f=2&t=96514 |
Author: | Ian_B [ Sun Dec 24, 2017 6:05 pm ] |
Post subject: | Ultrasonic Cleaner |
Anyone got one recommend one Comments please . |
Author: | Ian_B [ Tue Dec 26, 2017 12:45 pm ] |
Post subject: | Re: Ultrasonic Cleaner |
Nope new idea Have 2 kilos of white powder coming ![]() |
Author: | drmini in aust [ Tue Dec 26, 2017 9:36 pm ] |
On that note I've been told lemon juice and a toothbrush scrub works well on carbs too. |
Author: | Ian_B [ Wed Dec 27, 2017 12:09 pm ] |
Thanks Kev will post results as long as police dont intercept my white powder lol ![]() |
Author: | phillb [ Wed Dec 27, 2017 1:02 pm ] |
We use ultrasonics in my work. The key is a combination of the carrier solution and the ultrasonic action. The main advantage is it can loosen areas to small to access with a brush. Sent from my iPhone using Tapatalk |
Author: | goodie [ Wed Dec 27, 2017 6:38 pm ] |
drmini in aust wrote: On that note I've been told lemon juice and a toothbrush scrub works well on carbs too. Just to add , i remember reading somewhere ( may of been here ) that "boiling" alloy parts in lemon juice works good as well , i was going to try it ages ago on an 1/12" carby to test the theory, brought the lemon juice and they are still sitting on the shelf in the shed . ![]() ![]() |
Author: | Timbo [ Thu Dec 28, 2017 8:28 am ] |
phillb wrote: We use ultrasonics in my work. The key is a combination of the carrier solution and the ultrasonic action. The main advantage is it can loosen areas to small to access with a brush. Same here. They are fine for small fiddly mechanisms, etc, but not much chop on anything heavy. Tim |
Author: | Ian_B [ Sat Dec 30, 2017 1:49 pm ] |
Attachment: cleaner.jpg New idea that works Use the Docs method I suggest 1 hour not two My Dellortos turned grey then use this stuff from Repco Wow
Author: | Ian_B [ Sat Dec 30, 2017 5:27 pm ] |
What kitchens are for Attachment: sink.jpg
Author: | Ian_B [ Sat Dec 30, 2017 6:48 pm ] |
Highly recommend this autosol stuff on its own Magic results Docs method uses an alkaline degreaser It cleans the crap out of them but they went near black Fret not Chemistry says an acid will reverse that and yes it does.My carbs are now beautiful.I also used an acidic household cleaner to finish off. |
