brake MC CS mark 2 https://ausmini.com/forums/viewtopic.php?f=2&t=96506 |
Author: | p7676 [ Fri Dec 22, 2017 3:10 pm ] |
Post subject: | brake MC CS mark 2 |
Hello All, I am currently fitting my reco MC, the top threaded brake pipe hole has been previously stripped. Any way to fix it ? Allen |
Author: | Goldbrocade_62 [ Fri Dec 22, 2017 6:09 pm ] |
Post subject: | Re: brake MC CS mark 2 |
Hellicoil |
Author: | mini210 [ Fri Dec 22, 2017 10:15 pm ] |
Goldbrocade_62 wrote: Hellicoil Would the hellicoil hold pressure in the Master cylinder?? Is there a way of sealing the hellicoil when installed? |
Author: | gtogreen1969 [ Fri Dec 22, 2017 10:19 pm ] |
mini210 wrote: Goldbrocade_62 wrote: Hellicoil Would the hellicoil hold pressure in the Master cylinder?? Is there a way of sealing the hellicoil when installed? The sealing is done by the pipe flare and the seat in the MC. As long as the helicoil is not loose there shouldn't be a problem. |
