It is currently Fri Jul 18, 2025 11:28 am
 Post subject: No gears
PostPosted: Sun Dec 17, 2017 12:32 pm
My mini doesn't get used much. When I first drive it the gears are easy to select. After about 10 minutes driving, the gears become hard to select then soon after I can't select any gears. When the gear selection becomes hard and then nothing, the the clutch pedal feels soft to nothing, not nice and firm through the entire motion.
After about half an hour resting, It is good to go again through the cycle described.
Any ideas what's happening or needed to fix?
Thanks
 Post subject: Re: No gears
PostPosted: Sun Dec 17, 2017 12:46 pm
Top up the clutch master cylinder and bleed it at the slave cylinder nipple.
PostPosted: Sun Dec 17, 2017 2:00 pm
Thanks Dr, did that yesterday. Took the car for a drive today. Returned to the same scenario after ten minutes driving
PostPosted: Sun Dec 17, 2017 2:37 pm
When you bleed it did air come out? If so, do it again. If more air comes out the slave cylinder is sucking air. Some aftermarket slave cylinders (the cheapo ones) have no seal spreader like originals did.
Genuine AP cylinders still do.
Alternatively, PM me your address and I will send you a seal spreader. They are unavailable from Mini parts suppliers.
PostPosted: Sun Dec 17, 2017 4:15 pm
This "collector" has a little stockpile.
PostPosted: Sun Dec 17, 2017 4:19 pm
The slave cylinder is the original Lockheed. Might take it to the brake shop tomorrow for a rekit and see if that makes any difference.
PostPosted: Sun Dec 17, 2017 5:29 pm
Hone it and fit a new seal and boot. The seal is a std 7/8" cup, any brake shop would have one for $5.
I have never ever bought a new slave cylinder for my Minis. :wink:
PostPosted: Sun Dec 17, 2017 5:50 pm
Will let you know how I get on.
PostPosted: Thu Dec 21, 2017 12:15 pm
Fixed the slave cylinder. Good to go again.
Thanks for the assistance.
PostPosted: Thu Dec 21, 2017 1:32 pm
Have a good look at the flexible hose going to the slave cylinder as well...if old and perished, think about replacing it :-)
