It is currently Sun Jul 20, 2025 6:12 am
 Post subject: Rear Mini Wiring Loom
PostPosted: Thu Nov 02, 2017 2:50 pm
Whilst pulling my Cooper apart I found AYA9196 on the rear wiring loom.
When was this loom used (from date to finish date) and what models?
PostPosted: Thu Nov 02, 2017 3:07 pm
Here is a Picture
PostPosted: Thu Nov 02, 2017 4:39 pm
Looks like that body harness was used for the MK II Mini series beginning in 1969. No information on whether it was superceded before the end of round-nose production but I suspect not. Reversing lights weren't introduced until the Clubman series, except the SPO41 harness to enable reversing lights.
On the following page, S is for Saloon and V for Van.
PostPosted: Thu Nov 02, 2017 4:44 pm
The parts books show that loom as also being used in the early non-GT Clubman production.
PostPosted: Sat Nov 11, 2017 8:52 am
Thanks winabbey.
Do you have the illustrations referred to on the picture, if so, I am interested in seeing the Item illustration No.s 1B & 2D
PostPosted: Sat Nov 11, 2017 9:28 am
There is a difference between the Mini K rear wiring loom and the Cooper S, in that there is a need for a switched 12 volt wire to run to the rear mounted electric fuel pump. This is a white wire running in the middle pin if I remember correctly. Otherwise it is left empty.
PostPosted: Sat Nov 11, 2017 10:56 am
cooperess wrote:
Thanks winabbey.
The illustration page in the parts book just shows the routing of the harnesses, not the cable lengths, wiring colours and terminations that I suspect you are wanting? This information is in the workshop manual. Below are the relevant pages from the most comprehensive BMC produced workshop manual, TP832, the black covered publication.
I have a feeling the same loom was used but the fuel pump wire just taped up out of the way on the Mini K. I wonder if a Mini K owner could check their car and report back?
PostPosted: Sat Nov 11, 2017 11:11 am
The Mini K looms I have had had the center wire not fitted, but certainly may not be across the board. I would suppose they would share a part number if they were used on either model?
PostPosted: Sat Nov 11, 2017 12:22 pm
The rear wiring loom on my '69 Mk2 'S' has a white wire
PostPosted: Sat Nov 11, 2017 12:56 pm
which pin does it go to?
cooperess' loom appears to have a white wire, but doesn't go to the centre
PostPosted: Sat Nov 11, 2017 1:28 pm
Simon,
The white wire is on the ribbed edge of the block in the middle between purple wire and green with red trace. It's defineatly for the fuel pump.
PostPosted: Sat Nov 11, 2017 2:48 pm
My 70 Matic has no white wire, the pin is vacant. Ditto the loom in my son's 71 Clubby.
PostPosted: Thu Dec 07, 2017 11:20 pm
Doug,
Our Mini K is fairly early - YG2S1 776 - and has no white wire in the rear harness.
Don't listen to what I am saying... just understand what I mean.
PostPosted: Fri Dec 08, 2017 5:59 am
Tim I wrote:
Doug,
Ah OK, thanks. So the Cooper S had a different rear harness to the other models without electric pump. All adds to the knowledge base.
