https://ausmini.com/forums/
Spark plug adjustment
https://ausmini.com/forums/viewtopic.php?f=2&t=96403
Author:  shnitzee [ Sun Dec 03, 2017 6:07 pm ]
Post subject:  Spark plug adjustment
Hi all
Do I need to adjust the gaps on my plugs when installing electronic ignition kit + upgraded ignition coil?
Thanks
Eiles
Author:  gtogreen1969 [ Sun Dec 03, 2017 6:30 pm ]
Post subject:  Re: Spark plug adjustment
You can easily go out to 30thou from the std 25thou
Author:  shnitzee [ Sun Dec 03, 2017 6:35 pm ]
Author:  Besser [ Tue Dec 05, 2017 7:53 am ]
If you're going for maximum gap, don't forget to index them.
Author:  shnitzee [ Thu Dec 07, 2017 9:35 pm ]
How do i go about doing that?
Author:  drmini in aust [ Fri Dec 08, 2017 6:14 am ]
You put shims under each plug so the electrodes all point the same in the chamber. It's a V8 thing, not sure it makes a difference in an A series with siamesed ports.
Author:  shnitzee [ Fri Dec 08, 2017 8:17 pm ]
Thanks for info dr.
Never knew such a thing existed.
