It is currently Sun Jul 20, 2025 2:25 am
 Post subject: 3D printing Mini
PostPosted: Fri Dec 01, 2017 6:57 pm
Does anyone do or know someone doing 3D printing of Minis?
 Post subject: Re: 3D printing Mini
PostPosted: Fri Dec 01, 2017 7:49 pm
I have a 3D printer, I’d like to try if I could get hold of a 3D file.
It would be fun.
1970 Mk2 Cooper S
PostPosted: Fri Dec 01, 2017 11:41 pm
I think I have a file at work, its a round nose. What is your chosen poison (format)?
ill have a look on Monday
Nick
PostPosted: Sat Dec 02, 2017 7:22 am
I use slicer and it imports an STL file.
But, I use AutoCAD so Pre 2012 Acad 3d file would do too. (I've made small architectural models from my 3d 's.)
Mat
1970 Mk2 Cooper S
PostPosted: Sat Dec 02, 2017 9:31 am
I'd also be interested if you have the file, I've been trying to find a good 3d model of a mini for a while. If possible could you upload the format that allows editing, if it's a round nose I'll see if I can make a square nose version as well.
2015 Ducati 899 Panigale
PostPosted: Sat Dec 02, 2017 9:38 am
There are many websites with public source 3D print files, here is a mini
https://www.thingiverse.com/thing:1743636
https://www.thingiverse.com/thing:1616428
PostPosted: Sat Dec 02, 2017 6:44 pm
Are we talking 1:1 scale?!
PostPosted: Sun Dec 03, 2017 9:03 am
:mrgreen:
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
PostPosted: Sun Dec 03, 2017 7:47 pm
Depends on hoe big your 3D printer is.
A 3D model file can always be scaled up or down to suit whatever output you want.
PostPosted: Mon Dec 04, 2017 10:57 am
ok list of flie types as follows
.max
.dwg
.dxf
.rfa
.igs
.stl
Note I don't know the accuracy of these files.
Nick
PostPosted: Mon Dec 04, 2017 2:31 pm
.dwg or .stl are compatible with the software I have :)
PostPosted: Mon Dec 04, 2017 2:45 pm
Follow the link. (stealing works document transmittal system)
https://costinroe.box.com/v/mini3d
Password: thisisapassword
All the formats are here.
Nick
PostPosted: Mon Dec 04, 2017 5:51 pm
Like this one....
https://youtu.be/LJdW4HW-je0
PostPosted: Mon Dec 04, 2017 7:39 pm
So questions from a dumbass are..
what scale can these be?
what $$$ are we looking at?
are they cheaper with bulk (more than 1) production.... I doubt it
but then what am I to know, still not quite believing this type of thing can be made, but at same time with 80 year old unkle :oops: ...fathers brother :mrgreen: has recently had a hip replacement in UK done with these things.
PostPosted: Mon Dec 04, 2017 8:32 pm
Thanks for the files Hobson
That only depends on how big the 3d printer is, most are fairly small, but some are up to 500mm x 500mm x 500mm, which would give you a scale of about 1/7. In terms of how small, some printers are really accurate and you could have something suitable for a keychain.
This would depend on what material you want it made out of, the quality required and where you took it. Places like Officeworks can do them, but for a 1/7 scale probably between $500 - $1000 at a guess, this would mostly be due to the time it would take, guessing 2-3 days of printing. There are also people who have printers at home who make money on the side by printing stuff, this is usually a lot cheaper, think a couple of hundred dollars maybe, and finally there would be knowing someone who has one and asking them to do it, then it would likely be the cost of material plus a bit extra for the electricity for running it straight for 2-3 days, so around $50-$100 maybe.
With 3d printing generally not much cheaper in bulk as the biggest cost is the time it takes to print and the material. There aren't any setup or special fabricating/tooling costs like traditional manufacturing techniques so bulk doesn't really save set up time or anything like that.
It's an amazing technology that really is changing how things are made, Koenigsegg use it to 3d print the turbine housing for their turbos to make them spool better, the printing allows for complex designs that can't be cast or machined, Airbus and Boeing are 3d printing components for jet engines currently and in the near future they will be 3d printing entire jet engines for their airplanes, F1 extensively uses 3d printing for rapid prototyping and even down to cheap prosthetics for children are now crowdsourced from people with 3d printers in their home.
