It is currently Sun Jul 20, 2025 3:22 am
 Post subject: Gearbox problem
PostPosted: Tue Nov 28, 2017 6:49 am
Hey guys,
Got a gearbox problem on my 78 Chubby.
So first I bought a reconditioned motor and box from someone had gearbox problems with 2nd gear would not engage at all so sent the motor back to get another box this time with it hard getting into 1st and 2nd gear. Its really really hard to get into 1st or 2nd with running it or not. Sometimes it will go fairy easy into 1st but most of the time not so lucky. This time sent the whole car and to get it back with not only a a fair size bill but still got the problem. What would be causing for it to be hard to shift into those first 2 gears. All the rest of the gears are great.
Thanks
 Post subject: Re: Gearbox problem
PostPosted: Tue Nov 28, 2017 8:55 am
Many years ago I rebuilt a 4 synchro remote box with a similar 2nd gear problem.
When driving, sometimes it engaged perfectly and other times it wouldn't engage at all no matter what I did.
I had it apart, IIRC, twice before I found the problem.
I eventually found the problem was due to a poorly machined main shaft.
The main shaft splines for the 1st/2nd synchronizer hub assembly had been machined off centre.
The splines had been cut about 0.010-0.015" off centre.
This caused the synchro hub assembly to wobble and prevented the baulk ring/hub assembly from engaging with the 2nd gear.
It was an Italian made shaft but I can't remember if it was a genuine shaft or an aftermarket shaft.
Hope this helps.
RonR
68 build Mk1 Cooper S
PostPosted: Sat Dec 09, 2017 4:55 pm
Thanks for that mate.
I ended up getting a refund on the motor.
Now the same motor is up for sale again on eBay.
Feel sorry for the person who purchases it
PostPosted: Sat Dec 09, 2017 6:04 pm
Is it painted blue?
PostPosted: Sat Dec 09, 2017 7:58 pm
That's the one
PostPosted: Sat Dec 09, 2017 8:32 pm
Newyjim91 wrote:
That's the one
PM sent. :wink:
PostPosted: Sat Dec 09, 2017 9:39 pm
Hope they fixed the problem and not just give it a quick "makeover"
PostPosted: Sun Dec 10, 2017 5:54 am
It seems to me it's not a makeover it needs, but rather a strip and overhaul.
PostPosted: Sun Dec 10, 2017 7:48 pm
:lol: "Bench Tested"
PostPosted: Sun Dec 10, 2017 7:52 pm
It sat on the bench, and the bench didn't collapse :|
